Caddy Motor heating up - found rusted freeze plug
New to airboating. Recently bought a 15' rivermaster w a 472 caddy motor push a72x38 LXL. carb is a 600 2b holley on a stock manifold w 1" of spacers/ adapters. It will turn-up 2800-2900 maxed out. Motor has a RV cam and pistons.
Airboating is awesome. I like the caddy motor.
The 1st two times out it run great, temp hit 200 ( clam no wind conditions, not running hard . The 3rd time out temp climb up to 240 (windy condition running in the gulf. I shut it down to let it cool off. Ran back and never got over 210. The water pump bearings had play and a small leak. I replaced the water pump with a stock pump (could someone recommend a better water pump). Tested it on the trailer never got above 180 and took forever to get there. 4th Trip ran most of the day in the gulf loaded ran ok, Kind a felt like it lost power, sounded different. At the end of the day it ran up to 240 ( loaded into the wind). Once at home I noticed that there was a 11/16" freeze plug at the top inside of the head that was rusted through. No water. confused .... should there be water there was no loss of coolant . I started boat and could feel what felt like head pressure. Installed new freeze plug.
Boat sounds good again, seems like the freeze plug screw-up up the engine vacuum.
At this point I am unsure what steps to take next.
1. What is the passage that the freeze plug covers. coolant or something else.
2. What heat sensor should been used a temp gauge, I was told that the stock one only worked an idiot light??
3. How can I check gauge??
4. Radiator is 23x21, is that enough capacity?
5. Who makes an engine oil cooler for a caddy and how does it install?
Any help would be greatly appreciate.
Those cover/plug air pump passages in the exhaust ports. You did fine re plugging them to eliminate an exhaust leak. Running hot could've been from the bad pump. Does it use a thermostat? If it continues to run hot, you may have hurt a head gasket or simply had one deteriate (sp?) Napa makes a really good pump, but I have no problem with a new pump from most places. No rebuilds though. Just have to try it and see if it continues. Most likely had nothing to do with the little freeze plug.
Is the bypass open or closed (7/8 hole under thermostat) it should be closed if not runin the cadi thermo
Which way is better? If running a caddy thermostat is better, what temp caddy comes 180 pr 195 I think. Also a thermostat from any auto parts places as long as it is for my block?
If plugs bypass is better what do I use a 7/8" freeze plug?
All the info is great
