Smuggler
My cousin has a direct drive 500 caddy and I noticed that his vacuum advance is hooked up.. Waterthunder helped me out on my SBC timing. He told me what to set it at, what springs to use in the distributor and to plug off the vacuum advance.
Now I have the same questions for the 500 caddy.. I am thinking that if the advance is hooked up then we should just start fresh..
What should the timing be set at and and what RPM should it be at when setting it?
Should I buy another advance kit and use the same springs as I did on my SBC?
Should I plug off the advance on his also?
I would appreciate any info I can get.
Thanks!!
Thanks!!
