Oregonairboater
Greetings from Oregon! Being an Airboat owner in a State that may have but a dozen or so in its entirety, finding answers to Airboating questions is virtually non-existent. Finding this Forum looks to be a God Send. Anyway, 4 years ago I purchased a 2005 Rivermaster hull powered with a DD Caddy motor. It is utilizing the 72" three blade Whirlwind Super snapper prop, seats two rear (including operator) and 3 below. Pancake cage, 3/8" poly bottom, 15' 3" plus grass rake and a 7' 3" beam. Fiberglass hull. The engine had been overheated and needed to be rebuilt. Should have done my due diligence at that point, but greed/excitement won the day (price was $5000). Sooo, I rebuilt the engine (.040 over), but the kit I purchased came with a stock cam (due diligence should have started at this point.....). So now the problems/questions. At first, I had overheating issues, but finally solved that problem by adding an overflow tank that sat ABOVE the highest engine coolant level. Ran great, but would always hesitate when stomping on the throttle, thus taking getting up on a plane a bit longer and making steering at slow speeds iffy at best. Started replacing things. First, replaced the Carb. (original Rochester 4brl had been replaced with a Rochester 4brl for a 350 chevy). No difference. Went crazy and had the remanufactured Rochester I'd just received rejetted by a professional carb guy, also had him test the new HEI distributor for correctness, and while this was being done, went ahead and upgraded the rockers and installed the aluminum intake manifold from the CAD Company. Now the hesitation is worse, AND, it has a second hesitation at 2000rpm.
All this upgrading started because while cruising along merrily on our local Reservoir, alongside a biking path only 30' away, I was being PASSED by a guy on a bike! Holy Crap! So pulled out my phone and GPS'd my speed....32mph! (turning 2750rpm). Naturally, can't be slower than a bike, so had to do something about it. Now I don't know where to turn for advice. Instead of throwing 1000's of dollars at this engine, I should have moved on to something newer and stronger. Too late now. I've been in contact with Buddy Branch's widow, and she still has some of his custom cams for the 500, and even one of his last 800cfm thunder carbs. Would this be chasing the uncatchable dream? If I could lose the hesitation AND reach 50mph I'd be happy. Any ideas, thoughts, or comments will be greatly appreciated!
