Changed my 2.37-1 Rotator for a 2.68 Rotator swinging the 80 inch 3 blade Superwide Sensenich. I was shocked at the difference. This is my 4th gearbox---2 K-Ways (precursor to the stinger designed by Bruce Kay out of Tallahassee ), and two Rotators. I had my Propeller pitched at 22 degrees with the 2.37 and the engine set to hit 4600 wide open. I put the 2.68 box on Friday, and pitched the Sensenich at 32 degrees. Now thats a bunch of pitch! The engine turns the identical rpm it did before, but what a push! Cruise is now at 2800rpm and instead of 28mph it runs 32 in deep water just loafing along. Much better snap, damn near leapt over the trailer loading it because I wasnt used to the lunge when you tap the gas. Cannot say enough good about this swap. One thing to note---the sensenich marks are not equal at all. for the 1-2-3 settings. The digital protractor doesnt lie---Sensenich needs to fix this and I am going to call them about it. . Charles
