jdotson
Another head gasket...another day! Just when I thought I had my head gasket troubles behind me I lost another one Sat. on the canal to Lake Cypress. Engine has about 55 hrs on current head gaskets. The week prior, I had the vacuum advance seize up on my distributor causing a god awful idle that nearly shook the boat apart. I'm wondering if this could have created the gasket failure due to detonation? The part in the distributor that seized was not the vacuum advance canister but the mechanism that the canister moves. I replaced the distributor and put about 30-45 minutes total run time before the gasket let go and the temp shot up. Am I thinking in the right direction or do I need to be looking for something else? I did have the heads surfaced on a rebuild 55 hrs ago after going through several gaskets in the same amount of days. I don't want to go through that again! :angryfire: :angryfire:
