Wallace cam calculator is a neat online tool to blueprint what you are building, keep in mind that you want the torque curve to flatten out right where the prop will stall the engine at peak rpm, 750 CFM might be a bit much, gotta keep in mind even though engine is high performance and gear driven prop you are building a "tow truck engine" not a race car engine.
