I did not say anything about your LS motors. I suspect your LS motors are some kind of sweet!!!!!!!
What I am saying is this. In my opinion, A 347 cid engine will not thrust with a 500 cid caddy. Ain't gonna happen.
A really slow turning, flat pitched, wide blade will not match the thrust numbers created by a 500 cid caddy with a 2 to 1 reduction and a properly sized powerplus, or a k-series, or a stump puller.
The 500 caddy will out thrust the 347 cid engine by a vast amount. I felt like I was being conservative with the 200 pounds of thrust. I truly suspect the caddy will out thrust the slow spinning flat setup by as much as 500 pounds of thrust.
One thing I did notice is that you are not using the 347 cid engine and 504 ft lbs of torque in the same sentence.
There is no substitute for cubic inches. .
