The job sounds worse than it is, JD. It's just a matter of unbolting some stuff. I'm impressed that the unit didn't leave the man stranded.
I called ABD once to see if they had a recommended time change on a belt, and they said that they had tour boats out with over 2000 hrs. on them.
Look at it as an opportunity to check the mounting bolts for the housing, which might have worked loose by now.
feather
