cheap warpdrive blades
josh_2562
does any one have 4 warpdrive blade laying around they would like to sell cheap? I need them for my mini. The ones I have now are 52" and I got to set them at 20degs before it starts to slow the engine down at all. I can use up to a 72" blade. Thanks josh
I got 6 blades,were 72 inch originally, need to be cut down some, could probably get 4 at around 68 or 69 ok,
goldhunter_2":1ap5omd2 said:
now don't you wish you didn't cut those down :D
Yeah, I should have learned a little more about props before cuting it down. I was thinking more pitch would give it more push.
With my 52" set at 15degs if i give it a little push it will move about 10 feet on the grass then stop. Do you think longer blades will help it?
hows cajuns boat coming along. When you get his boat done there might be some videos of minis racing :D I think his boat will run dry when you get it done.
Have you messed with his pitch at all, If so what do you have it set at. Thanks josh
lgower how much you asking for the blades. I really only need the blades but if you have the hub how much for it to. You can pm me or post it here.
