FLrooter - Had a buddy that ran a 327 on a narrow wooden stick prop for a long time on a 1975 Panther hull. There are several engines that are better for DD, but just keep a few things in mind while you run and it will be ok.
First, it will probably run better with a narrow stick than a wooden paddle prop. Or at least that is how that old boat worked. With a wide paddle prop, it had much better response on the low RPM range, (we frogged by hand grabbing off the front deck) and climbed up on plane maybe a little faster with the wide blade, but then it dogged out and wouldn't make much speed. With the narrow stick prop, it took a few seconds to get up on plane, and you had to give it some RPMs to get it to climb up. You couldn't just slowly climb up onto plane, but seemed to have to give it a goose to get it to brake over on plane. However, it had much better top end speed and handled very well with that prop when on plane.
Second, it had to have 4 to 6 inches of water to idle along, and about 1 to 2 inches of water to run on plane. BUT DON'T STOP UNLESS YOU HAVE MANPOWER TO PULL HER OFF> or at least that was how this rig ran. She would get free in 4 inches but you had to give it the gas and wiggle the stick.
Third, it wouldn't run cattails, cane, or whip without several inches of water. And it didn't have thrust to push the vegetation down if you stopped in it when it was thick. But we learned to stomp down a small trail and we would whip that boat around and run back out our trail. (If it was tough to walk through them it wouldn't run far through them.)
Lastly, it would not run dry or grass with no water under it.
He figured that all out years before I met him, and when I learned to listen to him that it would not go where the seismic rigs I was running would go, it was a blast to run. I got her stuck more times than I can remember, and he would jump in the driver seat while I worked it to get it out.
The hull was a great slider hull and blast to run, but just plain aluminum. I wonder what it would have done with something on the bottom.
We all tend to forget that the early rigs were really low HP motors. There were lots of 60 and 90 HP continentals rigs around here in the early days (1960-1970s). I gave a fellow a ride a while back that used to run a 90 continental in the early 1970s and he was thrilled to see what I could run through and there are lots of better rigs around that what I drive.
Any airboat is better than walking or sitting on the bank watching. Good luck!
