cht on aircraft motor
My thought's exactly just to many people runnin the same trail. appreciate the info on shrouds i'm wanting to keep my continetal alive as long as possible. we should have the mazda rotary boat out in the next couple weeks now it's on a deck over step hull we'll try and catch up with you then.
Cracker we run a 13b fuel injected home built reduction box 3.17 to 1 ratio 80 inch 5 blade warp drive it was on a homebuilt 12fott yellow deck boat now it's going on my old psycho step boat should run skinny water real well buds also working on a turbo version of 13b putting out 300 plus hp. with 12-16 pounds of boost
Usually around 3000 for cruising 6800 max wich is just a little over 2000 on that 80 inch warp drive and with a big stainless muffler it's pretty quiet the motor has never been rebuilt it was a 37,000 mile motor when pulled from the car and this combo has been together for over 6 years and has several hundred hours on the boat with nothing but regular maintenance. and runs on 87 octane pump gas
the injection system is the factory efi that came with the car just wittled down to eliminate the unecessary stuff
