Some one mentioned an idea about just using polymer for the hull with some framework to support it. Crossed my mind prior to hearing it and after doing some research as to glues and sealants I thought it might be possible! BUT! does anyone know off hand the Coefficient of expansion or in simpler terms so I can understand what kind of rate everything expands/contracts at. If I built a tube steel frame with 1/2" poly with good support and if necessary slots to handle difference of expansion, Might work? You guys dont have to worry about the expansion issue as much. In the same context, If you built a mould and they injected a hull then built necessary braceing, or moulded the bracing into it. might work pretty good. Might not last 20 years but would probably pretty cheap to turn out the hull section.If everyones thinking the same, Somebodys not thinking! :wink:
