Conintal starter
Can anyone identify this starter so I can order another one? It's on a 6 cylinder conintal ground power.
This should steer you in the right direction, having rebuilt many starters of this type, I can say that most likely the brushes are stuck due to rust of the brush cage, remove back cover of motor, work the brushes free, derust the cage, paint with a zinc primer to prevent future rust, reassemble, it will last a long time.
That is a nippondenso starter you can get them from any auto parts store. They were used on alot of foreign car.
