Continental PE-150 Alternator
graywolf
I have a 13' Gilileo with a Continental gpu. I've got pretty much everything except for an alternator. There is a groove in the prop adapter, and the guy i bought the boat from gave me a bracket that's supposed to be for an alternator. Any suggestions as to what size, manufacturer, and installation setup I should use? Also, where can I get an air cleaner for this stock Zenith carb? Thanx.
Most people use a stock gm alt.some times you have to change pulley size so it will charge at idle. most times the prop adapter has the grove in it for the belt to run on. also when you get it all hooked up and have the right size belt buy two and zip tie one to the engine so if the belt you are running brakes you don't have to take the prop off to keep rideing.
