Not knowing your exact set-up, I would guess your problem is where you are measuring the toe in / toe out. 1/4" toe in on the leading edge translates to about 1" toe out on the trailing edge. Measuring the trailing edge, it should not be more than 1/4" toe out.rcm243 said:I`ve got about 1/4 in. toe in on the leading edge of the rudders.
