I just came into possession of a counter-rotator with a boat I just finished putting back together. It has a 496 8.1L engine with a 2-1 lower pulley.
I am pondering about switching the counter-rotator upper assembly into my other boat that has a 572 with a 2.3-1 lower pulley.
Does anybody have any suggestions on the prop setup for a 572 and a counter-rotator? Keep in mind that with a 2.3 reduction the front prop is a 3.5 reduction to the engine and the rear prop is a 2.3-1.
Right now with the 2-1 and the 8.1L, the front prop is a 3-1 to the engine and the rear at 2-1, I am running a sensenich 80" 3 blade wide (K) pitched at the last mark (3) and a 78" 3 blade narrow (H) pitched at (2). With the counter-rotator instructions dictating that most of the load be put on the front prop--I think I am about max on this set-up at least following the counter-rotator instructions. I think i could have possibly run 3-superwides S-blades on the front and just less pitch on the narrow on the rear.
With that in mind and a reduction that is steeper I think my 572 might run 4 superwides and 4 narrows. Diamondback says they run the narrows behind the superwides because when they ran wides behind them, they got some cavitation. Any suggestions??
