A
Anonymous
Guest
Interesting Tidbit
"Contra-rotating propellers, also referred to as coaxial contra-rotating propellers, are a complex way of applying the maximum power of a single piston or turboprop aircraft engine. Contra-rotating propellers are common in some marine transmission systems, in particular for medium to large size planing leisure crafts. Two propellers are arranged one behind the other, and power is transferred from the engine via a planetary gear transmission. The configuration can also be used in helicopter designs, where similar issues and principles of torque apply. Contra-rotating propellers should not be confused with Counter-rotating propellers, a term which describes twin-engined aircraft with the airscrew on one engine turning clockwise and the other counter-clockwise"
Ya'll have a safe weekend!
Felber
Felber
