jpatter123
Hi all, I am new to this forum and somewhat new to airboating. I bought a 10 foot sled about 5 months ago with a 360 lycoming. Now that I have a "little" experience I have decided to get a little bigger hull. I have an Ultra light diamondback 12' hull on order and plan to use the 360 on the new hull and before it gets here I have some questions about the motor.First off I was told by the guy who sold me the boat/motor that he had the motor recently rebuit with 160 hp pistons.
Now the ?'s
1. The motor seems horrid on fuel. I am running 100LL. Guys running much bigger boats with much bigger motors/props are getting better fuel economy then I am. I rarely run the boat over 2600 RPM mostly cruising at 2300/30-32 mph. Motor looks flawless. Burns very little oil, doesn't smoke doesn't leak and I see no fuel pissing out of the carb to indicate over pumping from the electric fuel pump. Is this normal? I talked to a guy who owned the boat a while ago and he said he could run all weekend on 20 gallons and I can barely get through a day on 20 gallons.
2. My little 10' gets stuck easy on dry ground. I have considered a new prop and even discussed with someone about buying their 4 blade warp drive today (I am turning a wood prop and don't know the pitch/length off the top of my head). Will I get better push with the warp drive? What effect will it have on fuel economy as well?
3. Rudder size. I am running 3 foot rudders right now and was told thats all I need for a little motor. I plan on ordering some new aerofoil rudders for the new boat and want to make sure I make the right choice. I'd like to know that I can upgrade the motor in the future and still use the same rudders. Will 3' be sufficient will 4' be too much?
3. I can't afford to put polymer on the boat right now so I plan to use either steelflex 2000 or frog spit. Which is better? It seems to me frogspit is much cheaper then steelflex is there a big difference in quality, smoothness or durability?
Thanks in advance.
Now the ?'s
Thanks in advance.
