goldhunter_2
I run the heck out of it this afternoon didn't even know the prop was back there I could swing 3000 easy probably could still handle more prop . fuel seems about the same But I did try a little more dry and climbs a small dry level or two and some long dry spots with me both boys guns and gear it did seem to push better on the dryer stuff and load with this 68x38 .
when i first started it or after I let it set about 1/2 hour I had to pump it like the other night but other wise I could shut off and start right back up no problem
PS I found your glasses out here can run them over sometime in the afternoon if you want
