Carb Shop
Ontario, CA · (909) 481-5816
They built mine and it was spot on. We tried a few change's when it was on the dyno and eventually got back to the same jets that the put in it to make max HP and Tq. If you call them you will need to know everything about your heads, cam, stroke bore and what RPM's your shooting for. When I called they seemed very knowledgeable about airboat carb needs. My Engine starts as if its fuel injection unless it has sat for a couple days then I have to pat the gas once or twice but it has never stumbled on the trails or bouncing around on the dry ground. Good Luck.
