brouss2785
Active member
Got a fuel injected io 520 with individual cht probes (p-100) in each cylinder and gami injectors. I noticed cylinder 1 and 5 are running hot I think I hit 490 on cylinder 1 and 450 on 5. On the river cruising 2300 ish what could be causing this? All other cylinders were under or at 400.Timing is at 22 degrees running av gas, oil temp never got over 140.
Do I have an intake leak possibly and maybe I need a cowl ? Pictures of cowling would be great.
