A
Anonymous
Guest
Well, I've been making my metal work. First I realized that I had set everything up without the flex plate, and a cross bar I had put in would not clear it. No problem, I dropped down on the X brace and welded in another piece so I could cut out the offending brace. Problem solved.
Now I have realized another problem. The X brace itself will not clear the oil filter!
Rather than cut everything out and start over, I figured maybe I can cut into the offending section of the X brace about half way, and weld in a piece of 1/4" flat stock.
Shouldn't cause a problem should it? I don't see any other way to fix it without wasting a lot of metal, and I'm starting to run out of 1" square stock. What do you think?
