Deal for some one
c chardt
I have a full set of metal works on 36" stringers with built in jacks aluminum floor boards single driver, double rear with complete seats and rain covers ,Baskets under both seats, gauges and panel & switches, double battery switch and 2 batteries all wired up and running,
Rudders, and complete steering, throttle pedal & cable 30 gallon tank , aluminum radiator & aluminum tubes motor never goes over 160 no madder how hard you run it!
also airboat trailer avaliable for $500.00 more
and all of rigging and motor was new in the middle of 05
Running 350 that is .30 over aluminum intake, small cam , newer holley 700 carb & spacer & 7 qt oil pan with hv pump motor runs at 60 psi , headers and exhaust
This will make some one a great drop in set up $5000.00 OBO
((((( NOW YOU WILL NEED YOUR OWN GEAR BOX, PROP & HULL )))))))
This in is a 14 by 7.5 aluminum hull and can be ran before it gets took apart
$5000.00 OBO
321 863 2312
This is when the boat was done and is the metal works and engine
MAKE ME AN OFFER
Make me an offer I have a new motor being built and I'm going to build a new different style of metal works and have new seats and all new parts so this stuff will just be setting around here in the next few weeks I will be taking it out of the boat
also have a trailer that i will let go with all of the rest of the stuff
I'll sell the whole boat for $15000.00 OBO and it has a 2.68 and super wide already on it. boat rides great and handles great will run dry also set up for a removable front seat so it could hold 4 people
Price drop $10000.00 almost everything
All you will need is your own prop and gear box every thing else is there[/b]
