SWAMPHUNTER45 said:Fool if you get time one day could you post a pic of the port and the scan tool you use to read it please.
Do you scan from a hand held device or a laptop and do you need special software ?
digginfool said:The software I use is called Diacom from Rinda Technologies. They have interfaces for almost every marine product out there (including PCM, Mercury, Marine Power, Seven Marine, and many others). Looking at their site, I see that the adapter used on Marine Power is the same used on PCM so the plugs are exactly the same. The two pictures I'm posting is where the plug sits normally and then lifted up for access. It requires a laptop. They do sell a handheld unit but it is nowhere near as useful. The information you can pull is amazing.
EastBay said:SWAMPHUNTER45 said:Fool if you get time one day could you post a pic of the port and the scan tool you use to read it please.
Hey! I am not an Idiot! Probably have blueprinted more engines than you can imagine! Just asking about port location. Do not say fool...i have followed many of your responses....thought you are a okay...righteous guy!
Come slide the Apalachicola River and the other rivers.
Eastbay
EastBay said:digginfool said:The software I use is called Diacom from Rinda Technologies. They have interfaces for almost every marine product out there (including PCM, Mercury, Marine Power, Seven Marine, and many others). Looking at their site, I see that the adapter used on Marine Power is the same used on PCM so the plugs are exactly the same. The two pictures I'm posting is where the plug sits normally and then lifted up for access. It requires a laptop. They do sell a handheld unit but it is nowhere near as useful. The information you can pull is amazing.
Hello,
Thank you very much! Just saw the other wire entering it..did not know what to make of it!
Thanks again!
Appreciate it
Eastbay
