Joe
Heres some fuzzy cell phone pix of the shaft and odds and ends today. note the Marlboro Box.... there is a Queen Fireant I found inside the distributir. This may be your BUG ! LOL
You can see the scoring on the shaft at the lower bushing, and the pitted rust area above that. Neither are good but neither will keep it from working, there is not any excess play end to end or side to side. There is a shot of the full length shaft and the gear sitting to one sied. The pix of the hold down part and the single "E" clip is how it came apart. There are now 2 E-clips there and not shown is the missing snap ring under the reluctor. Just for everyone elses info, this was a new-rebuilt distributor a few years ago. New and missing parts, hows that folks for rebuilders.
Note the wear spot from a heavy load on the side of the oil pump drive. A little shine here is normal but I see pressure wear there. Nothing that will harm the distributir or oil pump but its more than I have ever seen right there.
Was going to comment on something else. Oh yes ! The shot of the end of the casing shows no real vertical wear or pressure at the washers above the gear. No hard wear in the bushing or around it. All is snug, but the scarring on the shaft matches inside the busing inside.
The rotor button nose was bent from a hit with the distributor cap at some point in its life, I stuck a new cap from another distributor I had here on it. Its never been run in an engine, I got it new for the distributor for some experiments I was doing a couple years ago. Just ran the distributor with my battery powered drill. The button is new, though not yesterday LOL.
This distributor should run fine with a new gear, I see nothing to kill it. Just a bunch of little stuff thats more of a curiosity than damaging.
http://www.ursinecom.com/gallery2/main. ... temId=6502
Scotty
