OK I'm think about putting a motorcycle engine on a mini. this will be the first air boat i have ever messed with. if i got this right let me know if not correct me. the ideal is to swing the bigest prop you can and stay where your engine make hp am i right or wrong? lets say i had a 3./1 reduction and a prop with a 3000rpm max does that mean i could turn the engine up to 9000rpms? What i was think is i could get a porp with a lot of pith and use the gears on the engine to get it moveing then use the gear on the engine to get it to a safe crusie rpm. do you thank this would work? thanks for the help
