Once the plug wire cap is pulled off, inspect the insulator for carbon tracing of each dead cylinder, then inspect the distributor block for the same thing, I'd suggest replacing the insulator, you may have to pull out distributor block and media blast it with fine glass bead, if there are cracks in the block, replace it as well, could be from leaking oil seal, or moisture.
In either case, you want it all clean, dry, and no oils, or grease of any sort on insulator or block, a thin coat of flange sealant at the mating surfaces of the wire cap and case for good measure is fine.
