E series engine gaskets FOR SALE!
Hey guys! I'm coming to you from the airplane world and have found that some of you are powered by the same great Continental E series engine we have in our early Beechcraft Bonanzas! I have great news for you!
Peck's Custom Gaskets by McPeck Aviation is proud to offer complete engine gasket kits in fiberglass reinforced silicone AMS3320 in OEM .032" thickness. Old paper gaskets take on oil, heat, cure and then crack. Reinforced silicone can not be impregnated with oil eliminating this problem. This material mounts on a clean surface which eliminates scraping saving a lot of time and reduces the risk of damaging the mating surface.
Because the material is reinforced it will not extrude or squish like regular silicone gaskets. The reinforcement allows for torque to be maintained cutting leaks. It would also be reusable. If you were to ever have to remove an accessory for any reason you no longer need to replace the gasket.
E series engine kit pricing:
Accessory case kit $127.50
Lower engine kit $67.50
Pushrod tube kit $45
Complete Engine $225
Rocker valve cover gasket kits available separately.
With or without hardware.
I ship free! PayPal or check.
The E engine is notorious for leaking. This no longer has to be the case. Seal up your engine with a Peck Custom Gasket kit. The best material makes the best gaskets!
If you have other engine gasket needs automotive, aircraft or otherwise please let me know! I can make anything you need. Same great material!
Nothing worse than a leaking engine! I'm doing by best to help out. All precision steel rule die. E engines available now. Any other engine aircraft or auto just let me know and I'll get tooled up! Easiest to work from a sample gasket but if they are rare or hard to find I can reverse engineer from the connecting parts. Let me know what I can do for you!
Interested in a set for Lycoming. Near term need for a 320 getting a fresh up and would also be interested in a 540 set.
Hay....
My Continental does not leak....... It’s simply marking its territory !
Snicker....
AirHog
PM sent! Any other 320/540 owners out there needing gaskets!? Group buy helps keep pricing low!
Does anyone have the telephone number for Peck’s customs gaskets. I need To order a complete io 540 angle valve gasket kit & 1 io 360 Angle valve complete gasket kit. thank you and have a good day
I have used a set on my SV540 and another on a O320. Just recently bought a set for my AV540 but have not yet installed. No leaks so far and I have reused the carb and intake gaskets successfully. I like them, good luck.
asmcpeck@msn.com
