This is my problem, I have a 4 cylinder GPU cont. (PE90) with the bigger jugs(I believe the 0-470). I was told producing 150 hp at 2700 RPM, 68 x 34 stick, one mag, two barrell holley carb with a ported manifold. My problem is that when I step on the gas, it seems like it is lagging behind, like starving for fuel. However when I slowly accerate, it runs fine. I just put the new carb setup on thinking it would help, but it still lags like it performed with the one barrell zenith. So I wouldnt think the carb is the problem since both do it. This is what I know. I do have an air leak, on all four cylinders, where the intake pipes go into the heads. I know this because when I changed the carb around, all the heads had water inside when i pulled the intake pipes off. Could this be the main problem? I always heard that if you had any type of air leak going into your heads, it wouldnt run. But mine runs fine as long as you dont step on the gas all at once. Any advice? Or could it be that my prop is too big for that motor to sling? Will sling it at 2700. Thanks for the help guys
