No problem, Your seals will be two halfs. The ones I took out were flush with the block. The ones I put in are flush with the block. Mine were felpro and the instructions stated to set them flush with the block. Dropped the pan, pulled off the main bearing cap. Try tapping the seal out. If no luck, undo the next bearing cap to relieve some of the pressure on the seal. Your oil pickup tube might be attached to that one. If its still hard to hit the seal out, losen the next one also. Just losen them don't take them off. I used a small torx head screw driver and tapped the end till it moved about a 1/2 in. Then I was able to take it out with my fingers. You can use pliers to pull it out. Put the seal in with the open end toward the front of the motor. The numbers on the seal should face the fly wheel. oil the new seal, slide it in. Dry the oil off the ends of both after install. tighten your cap back at 90 ft. lbs. torque. Don't tighten it down in one shot. Alternate tightning until you reach 90 on the caps you losen also. Don't forget about them. Make sure all are tight. Scrape the old gasket material off the block and pan. Then put new seals on the pan. Used a tack sealer on my pan gaskets, just a touch though, don't want to get the excess in the motor. Had to hit my holes on the pan with a hammer because someone tightend them too tight and distorted them. Just tighten the pan bolts enough to get a little squish out of the gasket. Hope I got to you in time before you get started.
