futura Member Feb 21, 2005 #1 What are the differances between using round or 1 inch square tubing for a engine stand for a 0520 which is stronger or more desirable to use and is there any diagram or picture on the net that shows the desired design for construction. Thanks
c chardt Well-known member Feb 21, 2005 #2 It dose not matter what it is made from round or square they use hydraulic round tube because it it thicker than conduit and stronger
