First off, don't even consider mixing methods from car-motor boats. It's a GPU, not a SBC.
Second, if you ABSOLUTELY cannot get 100LL Avgas, use an octane booster (like 1 bottle per 15 gallons of 93 octane, or whatever.) Also, with the 100LL, your engine will run cooler.
Third, NGK AB-6 spark plugs have by far outperformed the others in my 220.
Last, letting the boat idle is key, but if you run the right fuel through the thing in the first place, little problems like that tend to correct themselves.
Bob
