Ever heard of Ground Grease?
ricmey1
OK, What's up with this ground grease stuff, a buddy of mine mentioned it. He says the guys on kissimmee run it?
Ground Grease is the slick bottom made by Greg Thomas out of lake Wales. I use it. It is very tough and slick compared to Frog Spit. It is probably neck and neck with Predator's slick bottom mix.
Adam
BLACKPOWDER , I HAVE STEEL FLEX NOW, BUT I WILL BE NEEDING SOME SLICK IN THE NEAR FUTURE. IS IT ANY BETTER THAN STEEL FLEX AND HOW CAN I GET SOME GREASE.
ITD, I am not familiar with SteelFlex but Greg's ground grease is pretty tough and good and slick. I have seen Frog Spit, Greg's mix, and Bobby Jr.'s Predator mix and in my opinion the last two totally blow away frog spit. They both last longer and are slicker. Greg's may be a little cheaper per gallon but don't quote me on that...call Greg and Bobby to see for sure.
Greg's # is (863) 676-5093 or (863) 676-5947
Predator's # is 863-557-0098
You won't be dissappointed with either.
Adam
