G
GWTW-000
Guest
Can someone please explain Dyno Testing and the difference if any of horsepower and torque numbers from the way it is calculated on an airboat verses the test on a Chassis Dyno? On the Caddy as well as others prior to 1972. I think the HP numbers were calculated different than they are now. My new engine has been tested on a Chassis Dyno and produced 415 hp and 520 fp of torque. It had all of the bells and whistles when tested. Will this be the same no matter how it is tested or will it be different at the prop or fly wheel (flex plate)? Please enlighten this Georgia boy so I can talk intelligently on this subject. Without knowing it seem that it would have higher ratings not having a/c, power brakes, power steering etc. and only dealing with the crank.
Thanks
KJC
Thanks
KJC
