I will be doing some back to back testing between the Power Shift props, I will test a power plus which I found to be the best all around prop yet and the new Falcon series. I will compare required RPM’s for running dry and planning out in the water I will also test snap and the time it takes to travel an equal distance and what speed the boat runs. I will also see if there is a difference in GPH.
