Finally
Jimmy Rickards
I got to try my new prop and hull. 2 blade 78 in. Superwide with the 2.68 and a 13'6x 7'3 Cottonmouth. Cruise rpms 3300 to 3500 wot rpm is 4900. This prop seems to have a ton more push than my old one. I hit a trail with the bright green short grass and black on the bottom and never slowed down. I think I am going to very happy. :D :D :D
First off glad to hear you're up and running again. How smooth is the 2blade SW. I'm running a similar setup (14' Gileo, side by side seating etc.) and went with the 3blade R. My cruise is between 2700 and 2900 rpm deep water with WOT set at 5100rpm. I'm real happy with the push also and I don't exactly have a light boat. I finally got most of the vibration out of mine but was just curious about how smooth the 2 blade was.
Thanks
Also what prop were you running before? wasn't it a stump puller?
I got some vibration. I need to track the blades. Yeah I was running the 3 blade stump puller before. With this setup that superwide is a beast on the ground compared to it.
