Flipping a glass boat
Hardtimes
I need to flip over my 13 x 8 glass hull to do some glass work on the bottom side, all rigging is removed so boat is fully stripped. If i flip it over in the yard on some wood blocks will it damage the glass or crack a wall or the transom. Or is there a method typically used.
Put it on saw horses, on the stringers, it's a good height to work on and can even walk on the hull if need be.
Definitely want it sitting on the stringers, the bottom should be true that way.
