OK
sorry this is from classic airboats site,they all so make flex plates with different patterns,hope this clears things up for you8)
Place rotator on engine dowel pins and hand tighten securing bolts.
2. Rotate rotator dampner bolt holes to match bolt holes on automatic clutch plate.
3. Secure rotator attaching bolt to engine block using lock tight.
4. Insert spacer washer between automotive and roator flex plates.
5. Insert large flange bolt through rotator flex plate, through spacer washer, and through automatic flex plate. Secure large flange nut and hand tighten.
6. Rotate flex plates to next bolt hole and repeat Step 5.
7. Any automatic flex plate bolt holes that do not align with rotator flex plate bolt holes must be drilled. Use rotator flex plate bolt holes as pilots to drill finish holes in automotive flex plate.
8. Six flex plate nuts and bolts should be done in sequence. Bring torque gradually up to maximum of 35 ft. lbs. Use lock tight.
CAUTION: Do not "grunt down" and fully torque each bolt as it comes around. You need to bring up torque in sequence.
REMINDER: Use lock tight on all rotator hardware except prop bolts
8)
