Hi guys, nice to meet you.
Gben, thanks for the welcome why is it the Fort? is there a story there? I don't know why there aren't more turbos, other than turbo lag which under pressure mentioned, I think they are a pretty good way to make torque. Maybe the cost or the weight? Where I live I don't see airboats period so I really can't speak to it. Nearly every time I stop at a gas station here some guy comes up and wants to ask question about the boat for 15 minutes.
I got nothing against PVC and duct tape, I can fix about anything with JB weld, duct tape and tie wire.
I would use about anything for a prototype that wouldn't break up and get sucked in the engine or the prop. I was actually considering mocking one up out of duct board, I think carbon fiber might be pretty cool for the real thing though, these guys might be worth talking to -
http://www.crawfordcomposites.com/products.htm or these guys might be able to help as well -
http://www.ramairbox.com/home_page.html
Under pressure, yea, I like putting a pencil to stuff, I have been thinking about it for awhile, it's kind of like mental pushups.
And you are absolutely right, the only time this idea would make a lot of difference is when running up over 4000 engine rpm's, not necessarily a bad thing.
I know if I want real boost a blower is the answer, I might not spend a lot more money than I will have in this deal by the time I am done, and I don't even know if it will work.
My primary objective is to build a high torque motor that won't break. One of my reasons for considering this is I don't really need a lot more power, a little when I am at high rpm's would be nice, but not critical. I'm running a 502/502 with flowed and ported heads, and a trunnion shaft aluminum high ratio rocker arm system. Check these guys out -
http://www.dreracing.com/ that and the head work is where I put my money.
Some extra torque from boost that's made when I am at high rpm's and cool clean air is what I hope to get.
I think the best way to make power is with cubic inches, timing and flow. I think balancing the motor and blueprinting the lubrication system is essential if you expect an engine to hold up long at high rpm's, I've proven that to myself several times. I really don't like to subject a motor to the stress big blowers, nitrous, high compression and high rpm's put on an engine if I can get around it. I used think different, I even tried running straight oxygen in a motor once...it got a little hot, ran real good for a while though.
As I've gotten a little older I got tired of rebuilding them.
Just like you I've thought about the scoop idea too, had them on cars, and I'm not buying it. There is some interesting reading on the subject here -
http://www.snowgoercanada.com/tech_ram_air.shtml and here -
http://www.vetteguru.com/ramair/
What I'm talking about is not the same thing as "ram air". You have to be doing 300 mph for ram air to begin to compress air and have any effect. Which, by the way, is about what a prop will turn at high rpm's, I think, I haven't done the math on that one yet :wink:
As I understand it the reduction units are necessary because without them at high engine rpm's the props can turn in excess of the speed of sound (over 600 mph) which disrupts airflow and thrust is lost.
With a reduction unit, at high rpm's the prop is still turning and pushing air over 300 mph and in doing so compressing it. In order to make boost the air must be compressed to a higher pressure than the ambient atmospheric pressure. That is usable boost if you could deliver it to the engine. I don't think it makes any difference whether the boat is at cruise speed or coming up on plane, if it is pushing air 300+ mph it's compressing it. The times when the prop is at high rpm's are exactly when you need the boost and resultant torque such as when running ground, launching, running from the game warden etc... The rest of the time all it would do is supply plenty of cleaner cooler air than is available over the engine. Another advantage is no parasitic load on the engine when its not needed, or the extra moving parts and things to break associated with running blowers.
I think you also have a point about the constant pressure in the duct, but if it can hold pressure then I'm not sure it would be an issue. There would certainly be more air volume in the duct than the displacement of the engine,so it would never starve for air, unlike a lot of air filter boxes. And if the duct flowed the same or more than the air intake on the engine with at least 1-2 psi of pressure being applied to the intake end of the duct I would think it would stay relatively constant
as long as the rpm's stayed up. It probably would have some fluctuation or resonance due to the big blades popping by it, but I would think the volume of air in the duct would buffer that some. I'm not sure it would be much different than a blower or turbo other than the amount of boost and when you got it. There would be some lag compared to a blower, but a turbo isn't instant power either, and it wouldn't take air long to travel the 6-7 feet down the duct at 300+ mph.
Anyway, it helps me think to put it all down in writing, sorry to torture you guys with it. If it works well enough to be worthwhile maybe one of you can build the second one, these kind of deals always come out better the second time.
-John
