I'm using a Facet POSI-FLOSolid State Fuel Pump, 25 GPH / 1.5-4 PSI. as a lift pump to the high pressure mechanical pump for the injection system, I find that AC fuel pumps are not good at suction lifting fuel in a airboat, when normally they draw from wings above or slightly below the engine. The electric pump will get you home at a reduced rate and the mechanical will run the engine while in a power setting but doesn't idle very good, it goes into fuel starvation. Hope that helps you
