Currently having non stop issues with new boat and fuel pumps going bad. Fuel pump started with being mounted above tank with water separator and would keep running dry like it couldn’t keep up. After that we moved pump below tank on the floor to get it low as possible. Again after about an hour of running we ran out of pressure and pump started screaming. With coast guard regs our tank doesn’t have a port at the bottom of the tank. It’s an 80gal tank fed from the top. What’s everyone’s 2 cents on how to fix this problem? Add a port to the bottom of the tank and call it a day? Fuel line is -10 through pre filter to pump and then -6 to water separator and to the motor.
