digginfool
Ever since I went to the LSA in 2015, I've been running an Aeromotive A1000 Marine fuel pump with a Racor Water separator on the inlet side as well as the Aeromotive 100 micron inlet filter. I got a little over 400 hours out of the first pump before it failed. I sent it in to be rebuilt and purchased a replacement pump, that way I would have a spare. The new pump didn't even make it 100 hours before it failed (metal particles clogging up the 10 micron output filter causing low fuel pressure, forcing the engine into limp mode). I replaced that pump with the rebuilt original pump, sending it in for its own rebuild. The rebuilt pump didn't last 10 hours before failing in the same manner. I spoke to a tech at Aeromotive and while discussing the problem, he asked about my setup. He then advised me to move the water separator to the output side of the pump. This seemed very odd to me, especially thinking about what 65 psi might do to the seals on the filter housing and how fast the pump could empty my tank or cause a fire should fuel start leaking out. I'd never know until I felt the heat or ran out of gas as the fuel pump and water separator is mounted low under the seat rigging. Out of an abundance of caution, I went to the Racor site and found the maximum operating pressure for my water separator is 7 psi. Damn good thing I didn't do it. Now, that all being said, I still have this problem. TBH, my fuel tank is not sumped and I'm pulling from the top through a 3/8" pickup tube. I know this is not exactly an ideal setup, especially with the added vacuum head of the water separator and inlet fuel filter. I'd be happy with the 400 hours I got the first time around but can't live with sub-100 hour lifespans. I've thought about adding a low pressure lift pump for some time but one that matches the flow of an A1000 is pushing $400.00 on its own. It would be a huge job to replace the fuel tank for one that is sumped but if that's the path I have to take, I guess it is what it is. Any thoughts on using a lift pump as opposed to a sumped tank? Any alternative ideas out there?
