Gasket Trouble.......
duckluv26
I'm looking to replace several gaskets on my 0540 but I don't know the name of one of them. Its the shiney square (about 4" x 3") just in front of the prop, on the right toward the top. It has 4 bolts holding it on. Thanks...........
If it is the rectangle shaped box facing the side just to the top and right of the flywheel/prop, has sort of a triangle peak to it, it should be the governor drive.
If that is the part, the gasket is the governor gasket and its "VERY OLD" part number is 72053. The part book is 20+ years old.
