Gauges
bugkiller86
Im building an airboat and need some new gauges. I have an 0-320 and need to know what all gauges I will need? I would like all new but not super expensive. Thanks
telflex and isspro i think d-back sells both
id say oil temp and oil pressure tach and amp's for gauges
Go to classic airboats, they have what you need. You will need a volt meter, oil pres, oil temp, and tack, maybe a hobbs meter. I like the mechanic gauges. Don't use the tiny tubing for the oil pressure, they have the thick wall rubber tubing and the fitting. For the oil temp you will need a lycoming fitting for the sensor, some times you have to drill out the hole for the sensor to pass through. You can also add the cly temp guage.
