jpatter123
These questions are just for my general knowledge.
1. Does a gear reduction unit really multiply horsepower by a direct equation. Ie a 3 to 1 gear reduction doesn't make a 600 hp motor an 1800 hp motor does it? I have had several people say that to me about the units but for some reason that seems way over simplified to me.
2. Is a 1500 hp motor turning a prop at 1500 RPM any better then a 500 HP motor turning the same prop with the same pitch at the same RPM? Does the more horespower motor spinning the same prop better cause it can get it there faster? I understand the principle of a bigger motor able to turn a bigger prop.
3. If your motor will turn your prop at the max RPM for the prop what advantage would it be to put nitrous on it? Wouldn't you have to adjust the prop and pitch to where it max's out only when you hit the nitrous? Or is this another case of just getting the prop spinning at RPM quicker then just on motor.
4. Is there a point where you can the prop to RPM to quickly and loose traction ie thrust. example if I can spin my prop to 2000 RPM prop speed in 4 seconds but a super charged nitrous alcohol motor can do it in 1 will there always be enough air and traction to the prop?
think thats enough ?'s for now.
