GO-435 prop
signcypress
Active member
Hey folks i am looking for a 6 bolt hub that will slip on my spline shaft lycoming GO-0435. I have a 8 bolt hub now but can't find the right prop with an 8 bolt patern. Any body out their running a 0435 or GO-435 if so what are you swinging?
Thanks for any information.
Packman
It may be cheaper to have your machined and re-doweled to six, I do have one but it would be hard to let go. Oh, please put your location in your profile.
Dan Coffey
Have it retooled to a standard hub and it will open up your options. See mine.
DIXIENOURMOUS
http://www.southernairboat.com/classifieds/aircraft-engine/p65064-lycoming-o-435-continental-e-series-spline-prop-adapter.html
krazymatt
do you have any pictures with your flywheel off? interested in how you have your starter and alternator mounted and the brackets. I have the splined sleeve and getting lxl hub welded on it just need to figure out the accessory mounting. and what flywheel to use?
