Smuggler
I have been looking to buy another boat. This time I want to go with a gear reduction unit but I have a few questions..
1. I was curious as to why so many gear boats for sale have a ratio of more than 2 to 1? Some boats I see have 2.38 and I think I even seen some with a 2.73 to 1. Why is this? Even with a 2.38 to 1 you would have to turn the motor 7140 RPM to get the prop to turn the max of 3000. Isn't that to many RPMs for most motors unless you have major money invested in the motor?
2. Why not run a 1.73 to 1? Than you could get 3000 at the prop and only turn the motor 5190. That way you could save a bunch on building a race motor to handle 7000+ RPMs. Isn't the rule of thumb, 5000 rpm is what most motors will turn with ease, produce a good amount of HP and still be dependable?
3. To be honest I have already made my mind up and I am going with a Stinger box BUT my question here is... Are the gears interchangeable? Meaning if I bought a used boat with a 2+ to 1 gear ratio can I pull those gears and install 1.73 to 1 using all the same parts including the case, just change the gears?
Can someone out there answer these questions?
Thanks Chris
Thanks Chris
