GPU Cylinders
the closest guy to you is jim lawson in bradenton 941 746 2428 hes got lots of gpu stuff not junk
OVER BUDGET":t170tu0l said:
I lost two cylinders last night.Where is a good place to get two more?Thanks in advance.
Ok I've got chrome overhauled cylinders
Complete with valves. and new piston rings.Exchange $250 :D
I'll jump in and highly recommend the rebuilt chrome cylinders from Speed Wheelie. I replaced two cylinders on my PE-150 (220 GPU) and in a few hours it cut my oil use from 1 to 2 quarts per hour to 1 quart in 5 hours. The rings should be set by the time I reach 50 hours, however I only have about 10 hours on them and they are already doing the job. Fast turn around, high quality and a good price.
i have a 220 and when i do need cylinders do you recommend upgrading to a 470 ?
the 220 is already dual mag
You mean a 0520? If yes then yes is your answer. But you will have to bore out your case.
Why not 0470 aircraft cylinders? Couldn't you use them and not have to bore the case and still pickup a reasonable amount of power over gpu cylinders? Just wondering.
