I have an 0-290 gpu with a 150 sump. I run a MA4SPA carb on it. Unless you have a custom intake or the original sump it would be hard to run a auto carb on it. I have a 12 gallon tank and that usually lasts about 8-10 hrs. depending on how I run. MA-3SPA would also work but both will need to jetted correctly depending on what pistons, cylinders,etc. you have. Mine has dome tops with the cut valve reliefs , and all cylinders are p20's, so that's why I have the MA4SPA.
