GPU Timing
snielsen
How do I check the timing on my 0470. Do I need to check the timing? There seems to be ping or tick. Its hard to tell with all the others sounds coming from the motor.
At certain RPMs its very noticeable.
Yeah thay all tick...Now a ping that could be another story... Low octane, Advanced
timing, To much carbon on top of piston causing engine to pre lit..This will lead to detonation...If the timing is to high the engine will lay down and sputter ..At high RPM
is it hard to start when its hot ,or does it heat up quickly?these are sure signs your timing is advanced.
